Help!
A project log for Tube Train/Bus Bedside Departure Board
Want to time leaving home to perfection so you arrive just in time for next train or bus? You need a departure board in your own bedroom!
terryspitzterryspitz 04/04/2018 at 08:510 Comments
Everything was going well on this project until I started trying to solder together a stripboard prototype. I must have shorted something. Now my nodemcu can boot and run fine, but only when I disconnect the display while first booting it. After that I can connect the display and it runs fine. Anyone have any ideas?
Also I bought a few even smaller WiFi/Arduino chips, the WeMos D1 mini, but these also have problems powering the 1602 LCD display.  Time to break out the multimeter.
