I ran two tests today:
- does the overtemperature detection for the heaters work?
- how does the system act with galden inside?
Overtemperature Detection
Well, this one was easy. I implemented the overtemperature detection described in the previous log, fired up the heaters at 100% and got this (no galden in the oven):
- The oven was heated to about 60 °C in a previous run.
- It correctly switches off at about 255 °C (T_H, red plot, thermocouple close to the heaters)
- and back on again at 245 °C.
- Auto-off again at t = 250 s. I then manually set the desired power to 0%.
- The whole region around the heaters heats up quite quickly at about 1 K/s.
- Cooldown is slow. Really slow. Like a dead snail.
- Smoke came out from the gap between the aluminium chamber and the thermal insulation, and from the pressure compensation pipe. I don't know why, maybe 255 °C were jusst a bit too much for some component.
As a consequence to the smoke I lowered the overtemperature thresholds to 245 °C (off) and 240 °C (on). Going lower than that is probably not feasible because the galden evaporates at 230 °C and some margin is needed to actually get heat into the boiling galden.
I don't know where the kink in the T_I (chamber thermocouple) comes from.
With Galden filled in
First of all, yes it does!
But getting there was at least partway dangerous because I turned vapsy into a galden geyser for a moment. Here's what I did:
30 mL of galden were poured into the oven. The resulting liquid level is well below the PCB grate (?) and the chiller exit fitting, and some galden is in the tube between chamber and chiller. Here's a top view
of the PCB in the chamber:
Heaters at 100% (that's 400 W):
and after a while small drops of galden condensed at the lid's inner glass plate:
These drops grew with increasing steam quality in the chamber. When the chamber was filled with saturated steam, steam also exited through the chiller. This is when things got dangerous, because the power was still set to 100 %.
- After a short while galden vapor came out of the pressure compensation tube
- After another short while, liquid galden was pushed out
- I quickly set the power to 0, which the oven quickly reacted to by releasing no more galden.
What happened? My guess is that galden bubbles entered the chiller from below, pushing liquid galden out of the tube. This was most probably caused by the high heat flux, which was
Here is a plot extracted from the logs:
Let's start with the region t < 100 s: Both heaters and chamber heat up, the heaters are significantly warmer than the chamber. Nothing surprising here really.
t = 100 s: galden starts to evaporate. The boiling point is given at 230 °C, and looking at the raw data reveals that the heaters have roughly this temperature at that time. The evaporated galden brings a lot of heat into the chamber, which now heats up quicker than before (how cool is that!?) until it reaches 230 °C as well. Overtemperature protection doesn't kick in because the galden does a good job at cooling the heaters.
So up to t = 120 s or so nothing happens in the chiller, which quietly waits for something to be done, at about 20 °C. Now things get interesting and here's a zoomed in excerpt:
As soon as the chamber is saturated with galden vapor (t = 125 s), the chiller outlet temperature increases because the chiller now has to cool down a certain amount of galden per time. The theoretical maximum with a vaporization heat of 63J/g would be
assuming that there are no heat losses to the ambient. That's quite a lot and this small chiller certainly can't handle it:
- The chiller exit temperature rises rapidly (t = 130 s, T_C = 94 °C),
- until saturated galden reaches the exit, causing another increase in temperature (t = 133 s, T_C = 173 °C) because the vapor condenses in the massive fitting which also holds the thermocouple. Galden vapor exits through the pressure compensation pipe.
- Now liquid galden is pushed in by bubbles from below (t = 135 s, T_C = 194...
Well executed project and a great writeup!
