Chiller brazed
A project log for vapsy
A tiny vapor phase reflow oven
christophChristoph 09/04/2015 at 12:231 Comment
Chiller and fittings brazed with silver solder (650 °C, acethylene/oxygen flame) and sandblasted:
Turned out nicer than expected!
The screws are just there to prevent sand from getting into the chiller during sandblasting. The vertical pipe will be cut back later when I know how long I need it.
Note: you can also use a simple torch for brazing if your parts are small. It might take a bit longer, though. You can also use solder with a higher silver content, which melts at lower temperatures.
zakqwy wrote 09/04/2015 at 14:13 point
Wow, that looks fantastic!! Nice brazing work!
