sketch for timer
A project log for MMR-70 - cheap radio module
some experiments with the fm module that features an atmega32
davedarkodavedarko 08/31/2015 at 12:330 Comments
int output_pin = 15;
int randNumber;
ISR (TIMER2_COMP_vect)
  PORTD ^= ( 1 << PD7 );
void setup()
  randomSeed(analogRead(0));
  // set LED pin to ouput
  DDRD = ( 1 << PD7 );
//CTC Modus
  TCCR2 = (1 << WGM21);
//Prescaler 64
//3686400 / 64 / 440 = 131
  TCCR2 |= (1 << CS20);
  TCCR2 |= (1 << CS21);
//TCCR2 |= (1 << CS22);
//start with an A
  OCR2 = 131 - 1;
//Enable Compare Interrupt
  TIMSK |= (1<<OCIE2);
//Enable global Interrupts
  sei();
void loop()
  randNumber = random(256);
  OCR2 = randNumber;
  delay(250);
