Finishing the project / fixing a noise problem
A project log for Simple jog dial for stepper motor
This is a simple way to adjust the height on the z-axis of my lasercutter; just a jog dial, readout, and stepper controller
akaAKA 09/21/2015 at 01:020 Comments
Finally the 4-pole terminal blocks arrived from digikey and I was able to complete the first version of the project. Here's a photo of the installed terminal blocks.
I found, to my dismay, that there is some pretty untenable noise on the stepper lines - both when powering up and just in general. I threw a large electrolytic capacitor on the barrel jack terminals that appears to have mitigated most of the problems. Here's the cap I installed - this greenwire hack worked fine, but I'll update the board files to accommodate a real decoupling cap soon.
Three things prevent me from marking this project "done" and recommending that others try it:
Improvements aside, I'm happy to be able to move on to getting the rest of the K40 electronics working. Still a long way to go there, though!
