Step 2
A project log for Resurrecting Zurg (IoTron)
Update the Zurg room guardian with esp32 wifi notifcation and actions!
glennGlenn 09/02/2015 at 05:520 Comments
I vacuumed Zurg off and proceeded inspect the base first. Underneath we find
  1. Speaker
  2. Battery holder for 3 Double AA batteries
  3. Base switch to activate Zurg manually
  4. A play or try me switch. Base switch is currently working with this switch in either position. (Note: So I ended up looking up the instructions for Zurg and found out that you have to arm him in order to have him monitor the sector).
  5. Wire bridge PCB that handles the transition from the main PCB to the sensor, lights and motors in the main body. I expect it there to provide some possible strain relief and or just make assembly easier. See photo for connections.
  6. Main PCB is comprised of two parts. One smaller daughter board which just has a resister and one black blob, and the main board which has resistors, caps and transistors. All caps look to be okay (no swelling)
Next I took apart his body (reluctantly to determine which wires were for the sensor) and found
  1. Main body motor which turns his upper body and his head.
  2. Arm motor
  3. Mouth light
  4. Eye lights
  5. Gun light
  6. Sensor led
  7. Movement sensor (Looks to be a Photo Resistor). PCB marked RL-346E
I plan to use upverter to document the system and the circuit. Seems to be lots of room in the base to put an esp8266.
So for my project I will want to remote activate the Zurgotronic Patrol System (simulate base button press - twice quickly). Pass the sensor and led circuit via the esp8266 so i can control when the led lights or the Photo resistor is enabled. Optionally control how zrurg moves side to side by controlling his body motor. Add support for a camera to capture the intruder?
Most of these photos are self explanatory but I'll add captions for completeness
Base
Base switch
Speaker
Main PCB - Bottom View
Main PCB - Top View
Lots o hot glue
Main PCB - Blob View
- I am guessing it is some kind of MP3 player chip
Wire bridge PCB
Wire bridge PCB - close up
Wire bridge PCB - pinouts
Main body and arm motors
Wiring
Zone Activation LED and Light Sensor
