WT8266 Features
Core/Memory/System
• Tensilica L106, ultra-low power 32-bitmicro MCU, with 16-bit RSIC. The CPU clock speed is 80MHz. It can also reach a maximum value of 160MHz and Real Time Operation System (RTOS) is enabled
• RAM 36KB(Available)
• Flash 16Mbit
System
• 802.11 b/g/n
• WIFI 2.4 GHz, support WPA/WPA2
• Support STA/AP/STA+AP operation modes
• Integrated TCP/IP Stack
• Integrated TR switch, Balun, LNA, Power amplifier and matching network
• Integrated PLL, Regulator and power source management components
• PCB antenna
Radio/Power Consumption
• +20 dBm output power in 802.11b mode
• Deep sleep power <10uA, Power down leakage current < 5uA
• Wake up and transmit packets in < 2ms
• Standby power consumption < 1.0mW (DTIM3)
Peripherals and Interfaces
• Support SDIO 2.0, (H) SPI, UART, I2C, I2S, IR Remote Control, PWM, GPIO
• Supports MIMO 1×1 and 2×1, STBC, A-MPDU and A-MSDU aggregation and 0.4μs guard interval
• Integrated 10 bit high precision ADC
Support AT remote upgrades and cloud OTA upgrade
FCC/CE/RoHs
Size 18.6mm*15.0mm
Operating Voltage: 3.3V
Operating Temperature:-20-70°C
For more details you can contact support@wireless-tag.com
Ai-Thinker
Splendide_Mendax
1. we confirmed that we use 32M byte Flash( FM25Q32, it is 32M-BIT Serial Flash Memory with 4KB Sectors, Dual and Quad I/O SPI. thansk for your remding.
SEEED Studio version is 32M Flash, FCC/CE/RoHs certificated verison
2. yes, we have the tools and user mannual
3. ESP8266 is just a device, WT8266 is the module can be used directly for your proejct
