Again a first use
A project log for PINAPI 4.0
PINAPI is "PIN API" simplest possible, old roots.
antti-lukatsAntti Lukats 09/11/2015 at 07:350 Comments
A small c code snipptet is all that takes to convert an FPGA to in-system self test tool that reads "netlist" of exernal connections and does connectivity testing. Software is replacing old hard-coded designs that did only report success fail on simple pin to pin connectivity tests.
