Decoding Transmission #3
A project log for Lets Solve Hackaday.com/Space!
I figured I would start a project to crack the mystery that is hackaday.com/space.
tyler-andersonTyler Anderson 04/16/2014 at 06:330 Comments
Each of the images for Transmission #3 contains a block of hidden data at the end. Fire up a hex editor and search for FF D9. This indicates the end of a JPEG file. Everything after this is extra.
Rocket Picture
We can tell there is a PNG file hidden in the rocket picture because the extra block starts with ".PNG........IHDR" and ends with "IEND.B`." Heres the extracted image:
Turns out its a space suit skin for Minecraft! View it at http://minecraft.novaskin.me/
Telescope Pictures
In each of the telescope pictures, the extra data starts with "Salted__". So this means its encrypted with OpenSSL. After copying the data to it's own file, you can decrypt it with...
openssl enc -d -aes-256-cbc -in 1.bin -out 1.mp3 -pass pass:"Im floating in a most peculiar way"
These are the MP3 files extracted from each image:
Here is what the mp3's say:
Theres also more data hidden in these recording. The MP3 metadata has the following comments:
  1. Transmission received at T-1090800.0222786265106846
  2. Transmission received at T-1090800.0296872268554892
  3. No transmission
  4. No transmission
  5. No transmission
Also, if you have ffmpeg, try...
ffplay 1.mp3
...to get a Real Discrete Fourier Transform
