The wooden frame
A project log for G-Sensor LED wheel of fortune
Using the TI-Launchpad with a G-sensor, LED stripes, a car engine bearing and some wood we built a wheel of fortune
richard-deiningerRichard Deininger 09/03/2015 at 09:150 Comments
Since the led stripe would simulate the ball running inside the wheel I needed to cut two discs on my DIY router table cut a groove in one of the discs and glue (epoxy) the hole thing to some heavy duty ball bearings (from a car engine)
