Halfway through circuit design
A project log for ADS1292 Breakout Board
A simple breakout board for the TI ADS1292 Biomedical Front-End IC
Giovanni Cimolin da SilvaGiovanni Cimolin da Silva 09/06/2015 at 23:230 Comments
I'm almost finishing the circuit design.
All of the components values I've used are referenced in the datasheet of the IC.
I'm making the circuit using single supply 5V input wich then is regulated to 3.3V in two regulators in the board.
TODO:
- Find insulated connectors for electrode connection
- Design two power sources for the circuit: AVCC and DVDD
- Design 5v<-->3v3 converters for I/O and comm pins
