Finished circuit design!
A project log for ADS1292 Breakout Board
A simple breakout board for the TI ADS1292 Biomedical Front-End IC
Giovanni Cimolin da SilvaGiovanni Cimolin da Silva 09/22/2015 at 13:040 Comments
I have finally finished the circuit design!
It would be great to receive some feedback about my design.
I am starting the PCB project this week.
Here are a list of things that changed since the last update:
-->Power supplies
Two power supplies have been added, one for the analog side of the IC and the other for the digital part.
I'm using two LM1117 low-dropout regulators from TI, which have 3v3 fixed voltage and +-1% accuracy.
They are a bit of overkill but it is what I have in hand.
-->Connectors
I'm using a simple SIL 10 pin connector for communication and power, just to make it easy to plug into a breadboard.
For the electrodes I've chosen to use T-Block connectors.
