close-circle
Modified Neon Light Bulb Tester
$10 neon tube tester with modified 4x 9v dc battery power supply, modified antenna, + circuit bent bug zapper, with 2x 3.7 liion batteries.
close
Suppose to emit an "EMP" what ever it may be, it was a 555 timer circuit connected to a coil pack nothing two fancy or powerful the 555 covered the pulsed part and the electromagnetic energy was emitted threw the antenna boosted buy the coil pack.
Coye Knoll wrote 6 days ago point
i feel ya man step up or down?
because once the primary magnetic field induces into the secondary coil windings Kaboom
Ghost wrote 05/09/2016 at 23:44 point
do you thing its legal device
lantramnamcodon wrote 07/03/2016 at 11:35 point
are you kidding me?is the gun is legal in America?the important is what do you use it for and also depend will you be catching or not.
Take a piece of wire, bend it in such a way and stick directly into a wall outlet, for this is how simplistic something can be to cause such "Radio" interference of an undesired type. is that piece of wire a "legal" device? Who is a man, to state and put forth and limit the ability of another man.
call for back up
Coye Knoll wrote 09/20/2015 at 20:53 point
I keep getting zapped,
ZMOM1031 wrote 09/19/2015 at 08:28 point
This project is cool
Why not step?
