DIY Chumby-lite
ESP8266-based WiFi LED light controller and clock
Yet another ESP8266 hack: partly inspired by an ancient X10 alarm clock controller, and partly by the Chumby, this is a bedside touchscreen controller for WiFi LED lights, with a few extra features thrown in and planned.
  • Ucglib quick update
    Spiros Papadimitriou09/19/2015 at 03:27 0 comments
    A simple, 1-line change to set SPI clock to 32MHz (d-oh!) now gives ~15fps across the board: Much better! Just doing ucglib justice here... :)
  • XPT2046 touch on ESP8266
    Spiros Papadimitriou09/16/2015 at 16:35 1 comment
    We have touch input! First successful test:
    The chip is a TI ADS7843 clone (even table references in it's datasheet match TI's datasheet, and not it's own numbering -- had me scratching my head, until I found the TI datasheet, and then it made sense :).
    Had to write driver from scratch, to use hardware SPI (otherwise there aren't enough pins). MOSI/MISO/CLK are shared with the ILI9341 display driver. While at it, added support for differential mode (code I could find used bitbanged SPI and single-ended mode). The code is currently a frakking mess, but once cleaned up, it'll be on github.
    So, the $22 Digole can be replaced by a $7 generic module (running ucglib, a much nicer graphics lib, too!). Getting closer to the ~$13 mark, which makes much more sense for this device.
    Edit - initial code here: https://github.com/spapadim/XPT2046
  • Ucglib on ESP8266
    Spiros Papadimitriou09/13/2015 at 17:48 2 comments
    On the front of using a much cheaper display module, just got Ucglib running on Arduino for ESP:
    If interested to give it a try, my port is at https://github.com/spapadim/ucglib (let me know if it worked). It also requires two simple patches to the Arduino ESP install: https://gist.github.com/spapadim/a4bc258df47f00831006. I believe that u8glib could also be ported in a similar fashion (but not interested in doing it right now).
    Support for the touchscreen controller is still missing (shouldn't be hard, though).
    Note: there is also a port of ucglib to NodeMCU at https://github.com/devsaurus/nodemcu-firmware/tree/dev-ucglib (which convinced me to give the Arduino port a try; thanks!!). That port strips out most fonts from the source (avoiding this was the part that took me a while to get working).
  • Demo video
    Spiros Papadimitriou09/09/2015 at 18:23 0 comments
    Short video showing it in action:
View all 4 project logs
  • 1
    Step 1
    Please see this post for build details.
View all instructions
Vladi wrote 01/15/2017 at 14:28 point
So cool.. Nice, simple, elegant... I am interesting in files for 3d printing enclosure as well.. Hope you attach those here soon. Cheers
Danny Martin wrote 12/10/2016 at 18:14 point
Do you have the necessary files to 3D print the enclosure?
Dillon Nichols wrote 09/23/2016 at 13:52 point
I loved my Chumby and was upset when the touchscreen died. I attempted a similar smarthome control project with a STM32F429-DISCOVERY board and ESP chip but abandoned it for some reason. Love how cheap this is so I might give it a shot. And great advice on the XTC-3D, I attempted to "fix" a recent 3D print with liquid tape but it didn't turn out as nice as your case. Might have to pick some of that stuff up.
Craig Hissett wrote 03/24/2016 at 11:16 point
I flipping love this!!
I have an ESP or two that I want to do something with - this is absolutely perfect.
