Arduinosmartwatch battery cover.stl
Due to the lack of space in the watch I had to place the battery on the wrist band. This is the 3D print file for the battery cover.
Standard Tesselated Geometry - 631.85 kB - 09/13/2017 at 00:21
Download
Arudino_Smartwatch V1.2 Enlarged.stl
3D STL print file for the smart watch case.
Standard Tesselated Geometry - 520.06 kB - 09/13/2017 at 00:21
Download
ARUDINO_MAIN_WATCH(1).ino
This is the first revision of the code, it doesn't use an RTC module for timing and merely relies on the micro-controller alone. (it is a pretty primitive approach)
ino - 4.09 kB - 09/13/2017 at 00:16
Download
LICENSE
Freetronics OLED library license
license - 34.32 kB - 09/12/2017 at 04:10
Download
