Glassware has arrived
A project log for Kahve - The Cold Brew Coffee Machine
A simple, low tech, low cost cold brew coffee set up
paul-scottPaul Scott 10/09/2015 at 09:580 Comments
After ordering a custom beaker and some flasks, they have finally arrived!
Flat bottomed flask (2000ml) for catching the coffee after the drip system
A round bottomed flask (2000ml) for holding the ice, plus a stopper valve (full assembly) for letting the melted ice drip at a constant rate into the beaker.
Custom designed beaker (1000ml) with clamp and drainage hole at the bottom. The grounds will go into this beaker and the water will drip through slowly to the flat bottomed flask.
The old coffee machine looking on as we place the retort stand that will hold the cold brew equipment. Stand has a very heavy base and is solid in order to hold all the kit!
