All-Mode Raspberry Pi Imager
Multispectral (LWIR, NIR, Vis, UV) Imager and Imaging (NIR-Vis-UV) Polarimeter Based on the Raspberry Pi
This is the DOLPi-UI Universal imager. It is a Raspberry Pi 2-based camera capable of viewing and polarimetric imaging in the IR-VISIBLE-UV bands. A FLIR Lepton module extends its imaging (but not polarimetric) capabilities down to the longwave IR ("thermal IR"). Raspberry Pi is able to simultaneously present the thermal IR image while acquiring images in the near-IR, visible, and near-UV ranges.
Complete construction information available at: http://www.diyphysics.com/wp-content/uploads/2015/10/DOLPi_Polarimetric_Camera_D_Prutchi_2015_v5.pdf
View all instructions
