Code Overview 4: Data Logs​​​​​
A project log for HEXABITZ - Modular Electronics for REAL
A new kind of electronic prototyping!
HexabitzHexabitz 04/03/2018 at 03:100 Comments
Some modules like the mircoSD memory card module H1BR60 (previously H05R00) feature permanent logging functionality to a micro-SD card. You can create up to 10 simultaneous logs with up to 30 different variables across all logs. Logs are tabulated text files that consist of a header section, a bunch of columns, each representing a single logged variable and a bunch of rows, each representing the variables’ value at a given moment. Logs have two types: RATE and EVENT. The former type logs variable state periodically at a fixed rate, while the latter logs only a state change. Below is an example of RATE log
Datalog created by BOS V0.1.0 on H05R0Log type: Rate @ 10.00 Hz
Count    Float    UINT 32
1    120.400002    1123077325
2    120.400002    1123077325
3    120.400002    1123077325
4    120.400002    1123077325
5    120.400002    1123077325
6    120.400002    1123077325
And this is an example of an EVENT log:
Datalog created by BOS V0.1.0 on H05R0Log type: Events
Count,Switch 3 (E-stop)
11,RELEASED_FOR_2_SEC
21,CLICKED
31,CLICKED
41,PRESSED_FOR_1_SEC
59,RELEASED_FOR_2_SEC
65,CLICKED
Use this API to create a new log:
Module_Status CreateLog(const char* logName, logType_t type, float rate, delimiterFormat_t delimiterFormat, indexColumnFormat_t indexColumnFormat,const char* indexColumnLabel)
where:
This API returns:
Once a log has been created, you can add new variables to the log using this API:
Module_Status LogVar(const char* logName, logVarType_t type, uint32_t source, const char* ColumnLabel)
where:
This API returns:
Adding a variable to a log does not start the logging process automatically. You can use the StartLog()StopLog()PauseLog() and ResumeLog() APIs to control the logging process for each log independently. You can also delete a log from the uSD card using DeleteLog() API. Note: If the module booted without a uSD card (or with a malfunctioning one), the logging functionality will be aborted and the indicator LED will blink indefinitely. Just replace the card and reboot again to resume normal operation.
