How to make a pre-built array topology file
A project log for HEXABITZ - Modular Electronics for REAL
A new kind of electronic prototyping!
hexabitzHexabitz 04/03/2018 at 03:300 Comments
Inter-array communication in Hexabitz is done using a routing table stored in a special header (.h) file. This header file describes the number of modules and how they are connected to each other as well as other important information for the array, hence, it is called a topology header file. Currently, you need to make a topology file manually (by modifying an existing one) or ask the array generate it dynamically with the explore command and API. Later, we might provide a software tool to generate topology files especially for complex arrays. It is still a good practice, though, to go through creating a topology file for a simple array to help you understand the process.
An example topology header file is available here. It represents the array below.
What is inside a topology header file?
    BitzOS (BOS) V0.0.0 - Copyright (C) 2017 Hexabitz
    All rights reserved
    File Name     : topology_1.h
    Description   : Array topology definition.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __topology_1_H
#define __topology_1_H
#ifdef __cplusplus
 extern "C" {
#endif
#define _N    8                    // Number of array modules
// Array modules
#define _mod1	1<<3
#define _mod2	2<<3
#define _mod3	3<<3
#define _mod4	4<<3
#define _mod5	5<<3
#define _mod6	6<<3
#define _mod7	7<<3
#define _mod8	8<<3
// Topology
static uint16_t array[_N][7] = {
{ _H01R0, 0, 0, 0, _mod2|P5, 0, _mod3|P4},			// Module 1
{ _H01R0, 0, 0, _mod4|P6, 0, _mod1|P4, 0},			// Module 2
{ _H01R0, 0, 0, 0, _mod1|P6, 0, _mod5|P3},			// Module 3
{ _H01R0, 0, 0, _mod6|P6, _mod7|P6, 0, _mod2|P3},		// Module 4
{ _H01R0, 0, 0, _mod3|P6, 0, _mod7|P4, _mod8|P3},		// Module 5
{ _H01R0, 0, 0, 0, 0, _mod7|P1, _mod4|P3},			// Module 6
{ _H01R0, _mod6|P5, 0, _mod8|P4, _mod5|P5, 0, _mod4|P4},	// Module 7
{ _H01R0, 0, 0, _mod5|P6, _mod7|P3, 0, 0}			// Module 8
// Configurations for duplex serial ports
#if ( _module == 1 )
	#define	H01R0	1
	#define	_P1pol_normal	1
	#define	_P2pol_normal	1
	#define	_P3pol_normal	1
	#define	_P4pol_normal	1
	#define	_P5pol_normal	1
	#define	_P6pol_normal	1
#endif
#if ( _module == 2 )
	#define	H01R0	1
	#define	_P5pol_reversed	1
#endif
How to enable/disable a topology file?
You can add the topology header file to your project by un-commenting its include directive in BOS.h and replacing it with the file name:
/* Array topology */
#include <topology_1.h>
Modules can then be added to the same project using uVision Targets feature. Click on Manage Project Items >> New (insert) Project Targets and name them with module IDs to identify them. You can choose the current target from the Select Target drop-down menu. One important step after that is to go to each target and modify the following:
Once done, you can click on Batch Build and select all modules then Rebuild them all. We suggest to always do batch rebuild (and not build) before loading the code to make sure you don’t load an old one.
