• 1
    Step 1
    The off the shelve HAKKO controller from Ebay comes shrink wrapped with display and buttons integrated on the PCB. To make it more useable and have everything integrated into a nice case, I first desoldered the display such that I can put it on the front panel of the case.
  • 2
    Step 2
    The DC/DC boost converter is a 150W version which is a good safety margin. I regulated the output to 22V as the manufacturer of the HAKKO controller suggest anything between 19V and 24V ...
  • 3
    Step 3
    While at my FabLab, I used the laser cutter to make a custom box with 3mm MDF. I use the following website to quickly prototype boxes :
    http://www.makercase.com/
    Then you can add the necessary holes with your favorite CAD program.
