Some Housekeeping
A project log for ED-64: A discrete 8-bit computer
ED-64 will be an 8-bit computer built with discrete components, and will feature a ferrite core memory (documented as a separate project).
andrew-starrAndrew Starr 09/13/2016 at 09:013 Comments
Just a minor update - I have done some 'simplification': halved the instruction set to 8 instructions total, and reduced the ALU to 4 functions. This will allow a significant reduction in the amount of hardware I'll need to make, while still allowing meaningful programs to be written. I'm also taking some inspiration from the Kenbak-1 - the I/O has been reduced to one input and one output port of 8 bits each. If this seems extreme, recall that the T-1 is more or less an 'art project' - I'm not trying to replace a desktop PC.
And there's always I2C/SPI :)
Yann Guidon / YGDES wrote 09/13/2016 at 12:41 point
I'm sorry but it is way more than an art project ;-)
Yann Guidon / YGDES wrote 09/13/2016 at 12:39 point
more is less ? :-)
Andrew Starr wrote 09/14/2016 at 06:24 point
actually, less is just enough :)
