Some housekeeping
A project log for ED-64: A discrete 8-bit computer
ED-64 will be an 8-bit computer built with discrete components, and will feature a ferrite core memory (documented as a separate project).
andrew-starrAndrew Starr 03/20/2016 at 07:500 Comments
First of all, the overall design has been radically changed to something simpler and, I think, more elegant. See the 'Details' section for, well, details. There's a new architecture diagram and I have included a summary of the instruction format and opcodes.
Secondly, I have begun to release design files, starting with the logic gate modules. You'll find the KiCAD schematic and PCB files, as well as gerbers suitable for sending to a board house.
Lastly, I have just received the PCBs for core H-bridge drivers. There are 8 per module:
These drivers will need additional logic to set the individual H-bridge directions. This logic in turn will be controlled by the data state (whether we are writing a '0' or '1') and gated by the row/column address decoder outputs. I am currently prototyping the H-bridge control logic.
