rf24 driver library locking CPU while transmitting
A project log for wireless microphone digital
developing a digital wireless radio mic in both 2.4ghz and UHF
ben-bilesben biles 08/05/2016 at 06:020 Comments
I did some more tests just with I2S passthrough and the decimation. The deciamtion works fine even when doing some Serial.print(samples,BIN); to check samples are coming are going.
The millisecond I enable the rf24.send(samples, len); to send the 48 byte packet the samples freeze up. New plan !
going to try and use https://github.com/greiman/FreeRTOS-Arduino
freeRTOS scheduler library. No idea what i'm doing with it but hoping I can assign the RF function send to one task and the samples IO circular buffer and I2S some others !
