multithreaded thread safe re-entrant libraries
A project log for wireless microphone digital
developing a digital wireless radio mic in both 2.4ghz and UHF
ben-bilesben biles 08/07/2016 at 16:550 Comments
Soon into starting to use freeRTOS to try and tackle the timing issues i'm possibly having with I2S SSC and RH_R24 radio ( driver librarys should be multithreaded, thread safe re-entrant libraries ) are needed to use freeRTOS.
I ask on RadioHead forum ,. answer don't no. also freeRTOS requires pin 2&3 to be connected together. I'm using those pins , did'nt want to resolder to other pins. OK , going to stick to learning about SSC timing and see if I can sync the rf24.send(data.len); function call to that timer somhow. quite quicky I found the NVIC_EnableIRQ(SSC_IRQn); in HiFi.cpp ( the I2S driver code ) i am hoping I can sync the sending of the packet to the SSC inturrupt. I might have to write as simple radio send function myself if I can't get this to work.
http://asf.atmel.com/docs/latest/sam.drivers.ssc.unit_tests.sam3x_ek/html/group__sam__drivers__ssc__group.html#ga8a68bfe46c95c426ef07be3ca618a54b
