first version boards are in
A project log for LED displays on Arduinos - a collection
for building clocks and bring them anywhere you want, even integrated a temperature sensor, if you're into that kind of stuff
davedarkodavedarko 10/01/2015 at 22:560 Comments
and here is the code for the LM75 on board the trinket shield, which finally works.
 March 6, 2014
 Spark Fun Electronics
 Nathan Seidle
 Updates by Joel Bartlett
 This code is originally based Dean Reading's Library deanreading@hotmail.com
 http://arduino.cc/playground/Main/SevenSegmentLibrary
 He didn't have a license on it so I hope he doesn't mind me making it public domain:
 This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
 This sketch provides a simple counter example for the HP Bubble display from SparkFun.
 https://www.sparkfun.com/products/12710
 Pinout for HP Bubble Display:
 1:  Cathode 1
 2:  Anode E
 3:  Anode C
 4:  Cathode 3
 5:  Anode dp
 6:  Cathode 4
 7:  Anode G
 8:  Anode D
 9:  Anode F
 10: Cathode 2
 11: Anode B
 12: Anode A
#include <Wire.h>
#include "SevSeg.h"
//Create an instance of the object.
SevSeg myDisplay;
//Create global variables
unsigned long timer;
int deciSecond = 0;
int f;
void setup()
  Wire.begin();
  Serial.begin(9600);
  int displayType = COMMON_CATHODE; //Your display is either common cathode or common anode
  //This pinout is for a bubble dispaly
  //Declare what pins are connected to the GND pins (cathodes)
  int digit1 = 3; //Pin 1
  int digit2 = 4; //Pin 10
  int digit3 = 5; //Pin 4
  int digit4 = 6; //Pin 6
    //Declare what pins are connected to the segments (anodes)
  int segA = 8; //Pin 12
  int segB = 9; //Pin 11
  int segC = 10; //Pin 3
  int segD = 11; //Pin 8
  int segE = 12; //Pin 2
  int segF = 13; //Pin 9
  int segG = 14; //Pin 7
  int segDP= 15; //Pin 5
    int numberOfDigits = 4; //Do you have a 1, 2 or 4 digit display?
  myDisplay.Begin(displayType, numberOfDigits, digit1, digit2, digit3, digit4, segA, segB, segC, segD, segE, segF, segG, segDP);
  myDisplay.SetBrightness(100); //Set the display to 100% brightness level
  // timer = millis();
void loop()
    char tempString[10]; //Used for sprintf
    sprintf(tempString, "%4d", f); //Convert deciSecond into a string that is right adjusted
    myDisplay.DisplayString(tempString, 4); //(numberToDisplay, decimal point location in binary number [4 means the third digit])
if (millis() - timer >= 1000)
  Wire.write(0x00);
  Wire.requestFrom(72, 2);
  while(Wire.available())
    int8_t msb = Wire.read();
    int8_t lsb = Wire.read();
    // strip one bit of the lsb
    lsb = (lsb & 0x80 ) >> 7; // now lsb = 0 or 1
    f = msb * 10 + 5 * lsb;
    // add to to form an float
    Serial.println(f,1);
timer = millis();
