Joints Replaced
A project log for Stubby the (Teaching) Hexapod
100% open source robot platform with accessability and affordability in mind: teaching children of all ages about robots & programming
the-big-oneThe Big One 04/18/2014 at 00:420 Comments
I replaced the Chicago bolts today with normal 1/4" bolts + nuts.  I found the Chicago bolts were coming undone quite easily, and since you could not tighten each section (frame / leg / frame) independently, the entire leg assembly felt a bit sloppy.  It is quite a bit better now.
Everything taken apart:
Starting to re-assemble, using nuts and bolts:
