Programming model for Surfaces
The method used here is to package each geometric primitive (e.g. sphere) as a Matlab 'struct'. Geometric primitives are then grouped in a 'cell array'. The cell array is ultimately passed to the renderpatch function for conversion to a shaded polygon image or the renderwire function for conversion to a wireframe image.
Each geometric primitive struct may have several data fields. Each struct must have a faces field and a vertices field in order to be rendered. The vertices field of N vertices must be an Nx3 array. The faces field of M faces must be an Mxf array, where f would be 3 for a triangle list and 4 for a rectangle list. For example a struct called cube could be defined as:
cube.vertices=[ 0 0 0; 1 0 0; 1 1 0; 0 1 0; ...
                0 0 1; 1 0 1; 1 1 1; 0 1 1;];
cube.faces=[ 1 2 6 5; 2 3 7 6; 3 4 8 7; ...
             4 1 5 8; 1 2 3 4; 5 6 7 8; ] ;
Of course, it would be tedious to have to figure out the faces for spheres and other objects, so a set of prototype objects is included below.
There are several optional fields which can be defined. The field names are case-sensitive and must be all lower-case. If you do not specify a field value, its default value is used. All fields can be used with the renderpatch function. Only facecolor, edgecolor and visible may be used with renderwire. In addition, renderwire maps the facecolor to the edgecolor.
For instance for the cube struct you might want to specify
cube.facelighting='flat';   %flat shading with no edge interp
cube.facecolor=[.9,.2,.2];  %a red color
The renderers, renderpatch and renderwire expect a cell array as a parameter. The cell array should contain all objects to be rendered. The combine function described below concatenates objects in the correct format for the renderers. See the example code below for specific use.
The Matlab Code for Surfaces
The code is packaged as several Matlab functions so that is can be used in a natural fashion. The Matlab 'help' function will return information on each function.
Examples using Surfaces
  1. This short example draws a three segment arm-like device and rotates each segment.
    cyl = UnitCylinder(2);
    L1 = 3;
    L2 = 2;
    L3 = 1;
    radius = .3;
    w1 = 5;
    w2 = 10;
    w3 = 30;
    arm1 = translate(scale(cyl,radius,radius,L1/2),0,0,L1/2);
    arm1.facecolor = 'blue';
    arm2 = translate(scale(cyl,radius,radius,L2/2),0,0,L2/2);
    arm2.facecolor = 'green';
    arm3 = translate(scale(cyl,radius,radius,L3/2),0,0,L3/2);
    arm3.facecolor = 'red';
    angle1 = 0 ; angle2 = 0 ; angle3 = 0;
    for i = 1:36
        distal = combine(translate(rotateY(arm3,angle3),0,0,L2),arm2);
        distal = rotateY(distal, angle2);
        arm = combine(translate(distal,0,0,L1), arm1);
        arm = rotateY(arm, angle1);
        cla
        renderpatch(arm);
        camlight
        box on
        view(30,30)
        drawnow
        set(gca,'xlim',[-5 5],'ylim',[-5 5],'zlim',[-5 5])
        angle1 = angle1 + w1 ;
        angle2 = angle2 + w2 ;
        angle3 = angle3 + w3 ;
    end
  2. This program builds a water molecule, duplicates it, then flys the camera around the scene and makes a movie of the flight.
    clear all
    % Hydrogen
    H = UnitSphere(2);
    H.facecolor = 'blue';
    %Oxygen
    Rox = 1.4;
    Ox = scale(UnitSphere(2),Rox,Rox,Rox);
    Ox.facecolor = 'red';
    d = 1.4;   %approx O-H distance
    H1 = translate(H,d,0,0);
    ang = 107; %bond angle
    H2 = rotateY(H1,ang);
    water = combine(Ox,H1,H2);
    %approx Hydrogen bond distance
    water2 = combine(water,translate(rotateX(water,-45),1,2,3));
    %init 40 frames of a movie
    mov = moviein(40);
    framecount = 1;
    figure(1); clf;
    %draw the water and move the camera and make a movie
    for i=0:.1:1.57
        renderpatch(water2);
        camlight
        set(gca,'cameraposition',[20*cos(i),20*sin(i),0])
        set(gca,'cameratarget',[1,1,1])
        set(gca,'cameraupvector',[0 0 1])
        set(gca,'cameraviewangle',30)
        box on
        xlabel('x')
        ylabel('y')
        zlabel('z')
        mov(framecount) = getframe(gcf);
        framecount = framecount + 1;
    end
    figure(2); clf;
    axis off
    movie(mov,-5,15);
  3. The following code renders the image at the top of the page.
    clear all;
    clf;
    sphere1=UnitSphere(2);
    sphere1.facecolor='white';
    cyl1=UnitCylinder(1);
    cyl1=translate(scale(cyl1,.1,.1,.75),2.8,0,0);
    cyl1.facelighting='flat';
    cyl1.facecolor='yellow';
    octa1=UnitSphere(1);
    octa1.facecolor='red';
    octa1.facelighting='flat';
    octa1.specularstrength=.7;
    octa1=translate(octa1,1.8,0,0);
    %Animate
    for time=0:.1:4
       level2=combine(...
          rotateX(octa1,time*90), ...
          rotateX(cyl1, time*(-180)) );
       level1=combine(...
          level2, ...
          rotateY(level2,90), ...
          rotateY(level2,-90), ...
          rotateY(level2,180), ...
          rotateZ(level2,90), ...
          rotateZ(level2,-90)...
       base=rotateZ(combine(sphere1,level1),time*45);
       clf
       count=renderpatch(base);
       axis off;
       grid on
       daspect([1 1 1])
       light('position',[10,-10,10])
       %Do a persptective transform
       set(gca,'projection','perspective')
       set(gca,'CameraViewAngle',6)
       %The frame background color
       set(gcf,'color', [.6,.8,.8])
       xlabel('x');ylabel('y');zlabel('z');
       view(-28,20)
       drawnow;
    end %for
    rotate3d on
  4. This example constructs a simple airplane and rotates the props. Setting cockpit.facealpha=0.6 results in a transparent cockpit canopy.
  5. The UnitSphere, UnitTorus, and UnitCylinder shapes can be parametrically modified using a 'superquadric' formulation which results in 'squared off' shapes. Example images show the effect applied to a sphere and a torus.
  6. A student and I used this modeling system to build a simple maze. The maze was presented as both an overhead and in-the-maze view. We made a simple GUI to navigate the maze. There are two files necessary to run this example; maze6.m and maze6key.m. The first program defines the maze and a bunch of UIcontrols (see GUI design). The second program is a function which is called to implement camera movement through the maze. An example of the two views is shown below. The maze consists of a collection of scaled UnitCubes which are translated to various positions.
Constructive Solid Geometry (CSG)
The CSG description used here is very simple and limited to fairly coarse volume representations of solids. The scheme is to represent each elementary solid, e.g. cube, as a 3D field of values, negative on the inside and positive outside. The CSG operations of union, intersection, and subtraction then become simple min/max operations on the 3D fields. After all CSG operations are complete, the volume representation is converted to surfaces.
Programming model for CSG
All volume-shapes are generated as 3D scalar fields. These fields may be subjected to the usual CSG operations mentioned above. Since fields are really arrays, all fields which are to be combined must have the same number of elements. The 'resolution' parameter associated with construction of CSG objects sets the number of elements and thus must be the same for all CSG objects which will be combined using CSG operations. After all CSG operations are performed, the volume-object is converted to surfaces for rendering. The volume which is modeled by the CSG operations is hardcoded to -1 to +1 on each axis. Objects may be scaled after they are converted to surfaces. Objects may also have other parameters, such as facecolor, set after they are converted to surfaces. All objects are rendered using the routines described above.
You may use several distinct CSG objects in a scene. Each different object can have its own resolution.
Matlab code for CSG
As with surfaces, there are routines to build and modify CSG objects.
Examples Using CSG objects
The following code produces a cup sitting on a simple table as shown below.
%build a cup sitting on a table
clear all
clf
res=15 ;
%build the cup body
%by making a closed-end cylinder
cyl1=CSGcylinder(0,0,0,.45,'z',res);
cube1=CSGcube(0,0,-.5,.5,res);
body=CSGintersection(cyl1,cube1);
%then subtracting another, smaller cylinder
cyl2=CSGcylinder(0,0,0,.35,'z',res);
cube2=CSGcube(0,0,-.4,.4,res);
hole=CSGintersection(cyl2,cube2);
body=CSGsubtract(body,hole);
%make the handle
s1=CSGsphere(.6,0,-.4,.3,res);
cyl3=CSGcylinder(.6,0,-.4,.15,'y',res);
handle=CSGsubtract(s1,cyl3);
%join handle and body to make the cup
cup=CSGunion(body,handle);
cupSurface=CSGtoSurface(cup,res);
cupSurface.facecolor='yellow';
%now make a place to set the cup
table=UnitCube;
table.facecolor=[1,.6,.6];
table.facelighting='flat';
table.edgecolor='red';
table=scale(table,1,1,.2);
table=translate(table,0,0,-1.2);
scene=combine(cupSurface, table);
count=renderpatch(scene)
   axis off;
   grid on
   daspect([1 1 1])
   light('position',[10,0,10])
   %light('position',[10, 10, 10])
   set(gca,'CameraViewAngle',8)
   view(7,20)
   drawnow
rotate3d on
3D camera model
I started writing low level graphics code in Matlab a few years ago with the idea of using it in an introductory graphics course. The GUI and an associated function convert a 3D face list and vertex list into a 2D image.
