After uploading 4Duino you can now use the Home Security project.
Form 1 of Home Security Device: Input Password Interface
Form 3 of Home Security Device.
If the password entered is incorrect, it navigates to Form 3 (Error Page).
Upon entering the inverted password, this form would appear. Home Security Device also sends message to web server in the IP address of the 4duino Wi Fi Module
This message says that the owner of the house is present when a force entry was executed.
In this project, acrylic casing is used. Magnetic switch (as shown in the picture) can be attached to a door or vault. The buzzer can be mounted with the acrylic case.
