Design Deadline!
A project log for The Square Inch Project
A contest to create awesome, useful square inch boards. Entries are closed.
alphaninjaalpha_ninja 12/02/2015 at 00:3916 Comments
Hello!
The deadline originally set for today has been postponed to December 8, 2015. Same rules as last time: this is at 23:59 UTC, so you can look here to convert that into your timezone.
Here's what you need to do in the coming week:
  1. Finalize your design!
    1. There's no rule against creating a new revision before the contest ends, but you need to have a working circuit uploaded!
  2. Upload your schematic(s).
  3. Upload your BOM(s).
  4. Upload your design documents.
    1. This includes Gerber and Excellon drill files. DON'T FORGET THIS!
We will try to verify all projects' compliance with these rules by 23:59 UTC on December 7.
0miker0 wrote 12/02/2015 at 18:33 point
I just got a message to attach gerber files but there is no place to put them.? All I see are a description of the project and components.
alpha_ninja wrote 12/02/2015 at 19:58 point
Yes... The simplest solution is probably to upload them to GitHub or Dropbox and put a link onto your project page.
0miker0 wrote 12/02/2015 at 20:10 point
Sounds good and linked all manufacturing files to my git site on day one.
emmy.ydm wrote 12/02/2015 at 14:54 point
Hello guys, I think there is no need to worry about missing something, since the manufacturer will check it for you.
They always find mistake in my design for me, and inform me to correct that...very nice.
danjovic wrote 12/02/2015 at 13:38 point
Quick question: Wouldn't a board shared in OSHPARK be an equivalent (I men an alternative) to gerber files? The shared boards can be easily reproduced thus achieving one of the objectives of the project.
I now that gerber files are industry standard but most of us are hobbyists who etches our own boards or send the eagle files straight to a manufacturer (nevertheless eagle is more or less a standard pcb file format nowadays). The big issue with gerber files is that most of us will simply generate them using eagle cam processor but they will end up not being tested.  :)
alpha_ninja wrote 12/02/2015 at 14:01 point
Since you can download gerbers from there, yes.
K.C. Lee wrote 12/02/2015 at 15:20 point
Asking for *finalized* design files, part lists etc weeks before working boards pretty much means that the board files are going to be untested.
jaromir.sukuba wrote 12/02/2015 at 11:21 point
Hello - as a quick test, perhaps reference for other users: I generated gerber data using the iteadstudio CAM file - available at http://blog.iteadstudio.com/how-to-export-gerber-files-from-eagle/ - from Eagle. I use this procedure to generate manufacturing data for Itead, but I'd rather be sure this is OK for contest. Could you, please, take a look at https://github.com/jaromir-sukuba/micro_progmeter/tree/master/hw/gerber and check whether it is OK? There are more users using Eagle, so known and working CAM file could make their life easier.
They also have blog entry regarding the gerber data export from KiCad http://blog.iteadstudio.com/how-to-generate-gerber-files-from-kicad/ it could be helpful for KiCad users.
danjovic wrote 12/02/2015 at 13:39 point
Thanks! your article is very useful!
HappyFox wrote 12/02/2015 at 05:45 point
The Gerber files are available on the upverter project page. Is that cool ?
alpha_ninja wrote 12/02/2015 at 05:50 point
That's OK :)
HappyFox wrote 12/02/2015 at 04:52 point
I did my project on upverter ( https://upverter.com/HappyFox/ff755c4d871385dd/Square-Inch-Rover/ ) so all those files are there. What is the best way for me to link to that on my project ? The Description, build instructions, all the above ?
alpha_ninja wrote 12/02/2015 at 04:55 point
The links section would probably be the most fitting. However, don't forget to provide gerber files!
Jacob Creedon wrote 12/02/2015 at 01:01 point
How will verification of compliance be inidcated? Will you just comment on the project saying hey you have everything, or hey you are missing x?
mcu_nerd wrote 12/02/2015 at 02:04 point
Also wondering the same thing.
alpha_ninja wrote 12/02/2015 at 02:42 point
This is what we're planning to do.
