High and Low Voice Board done
A project log for c-ynth
A small drone synth based on "Devils Triangle Drone Synth" schematichs
woodworkerWooDWorkeR 02/01/2016 at 14:020 Comments
4 Voices are already done (2 per board), next up i will add another 2 Low Voices and a Power/Mixing Board.
I started with transferring the Schematic into KiCad and also will play around with +/- 12V (Eurorack Standard) instead of 9V and voltage divider as in the original project so it can be converted into a Eurorack Module.
