Hand soldered version done
A project log for c-ynth
A small drone synth based on "Devils Triangle Drone Synth" schematichs
woodworkerWooDWorkeR 03/13/2016 at 17:223 Comments
The hand soldered version of the c-ynth is done. And was already used at a so called "DrehCommando" which you can listen to here.
Unfortunately it seems that i miswired one of the low voices. But for a first try good enough. I will create a PCB for this and try to get the "wiring" done correctly this time.
Will post a few images of the finished build soon.
davedarko wrote 03/13/2016 at 18:40 point
although I saw an early version I have to ask for pics. Pigs. Pics. Pics or it didn't happen :)
WooDWorkeR wrote 03/13/2016 at 19:33 point
Pics will be taken tomorrow
davedarko wrote 03/13/2016 at 19:43 point
yay :)
