This code can be used on any project where your device connects to web page (on your phone). In contains all the necessary code to correctly size text which is often missing form example code on the net...
Screen displays:
- Displays Temperature etc...
- Turn On (Off) GPIO2 etc...
- Set GPIO4 High (Low) etc...
- Get System Status
Basic temperature sensing on ESP32 VROOM
Button to toggle GPIO2 On/Off
Button to set GPIO4 High/Low
Button to retrieve current setting and temperature...
All buttons toggle...
Pretty basic but can form the basis for more complicated endeavor for any ESP device...
Michael O'Toole
Dan Julio
Hello Micheal,
Good work. Thank you. when I running the code, screen displays is empty in web server. You have any idea why I have such kind of response. ?
