Other configuration tips from ALSA
A project log for Raspbian Squeezed
How I automate the slaughter of the Official Raspberry Pi's Debian-based OS to create reliable headless, embedded systems
yann-guidon-ygdesYann Guidon / YGDES 12/22/2015 at 20:420 Comments
http://wiki.linuxaudio.org/wiki/raspberrypi
The configuration of the Pi is not automated but the little script to configure JACK is similar to what I already do:
#!/bin/bash
## Stop the ntp service
sudo service ntp stop
## Stop the triggerhappy service
sudo service triggerhappy stop
## Stop the dbus service. Warning: this can cause unpredictable behaviour when running a desktop environment on the RPi
sudo service dbus stop
## Stop the console-kit-daemon service. Warning: this can cause unpredictable behaviour when running a desktop environment on the RPi
sudo killall console-kit-daemon
## Stop the polkitd service. Warning: this can cause unpredictable behaviour when running a desktop environment on the RPi
sudo killall polkitd
## Only needed when Jack2 is compiled with D-Bus support (Jack2 in the AutoStatic RPi audio repo is compiled without D-Bus support)
#export DBUS_SESSION_BUS_ADDRESS=unix:path=/run/dbus/system_bus_socket
## Remount /dev/shm to prevent memory allocation errors
sudo mount -o remount,size=128M /dev/shm
## Kill the usespace gnome virtual filesystem daemon. Warning: this can cause unpredictable behaviour when running a desktop environment on the RPi
killall gvfsd
## Kill the userspace D-Bus daemon. Warning: this can cause unpredictable behaviour when running a desktop environment on the RPi
killall dbus-daemon
## Kill the userspace dbus-launch daemon. Warning: this can cause unpredictable behaviour when running a desktop environment on the RPi
killall dbus-launch
## Uncomment if you'd like to disable the network adapter completely
#echo -n “1-1.1:1.0” | sudo tee /sys/bus/usb/drivers/smsc95xx/unbind
## In case the above line doesn't work try the following
#echo -n “1-1.1” | sudo tee /sys/bus/usb/drivers/usb/unbind
## Set the CPU scaling governor to performance
echo -n performance | sudo tee /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Except that I don't stop the services, I remove the corresponding packages...
