Shower curtain fastenings coming loose. A Hack fix
Quite often the track hooks would come out of the shower curtain track ... This can happen often and be a nuisance.
This can
Shower curtain fastenings coming loose. A Hack and fix
The issue is that the bottom gap where the track hooks slide is too wide, by a small amount.
Squeezing the track does not help because there are two sides to the track joined by a rubber type part that just springs the track back as it was reopening the gap again
Require two wooden spring pegs and a ladder to reach
Wooden pegs are use to grip better in the top slot but these may be subjects to mould in such a damp place, anti-mould treatment should help
Daily Motion Video How to
Shower curtain fastenings coming loose Hack and Fix
http://dai.ly/x37ufki
  • 1 × Two wooden spring pegs Used split apart to jam in to shower track gap
  • 1 × Step ladder To reach to the top of the shower track
  • 1
    Step 1
    Two wooden spring pegs, spit up the pegs for the four wedge shaped pieces of wood, the springs are not needed.
    Jam these piece of wood at a spaced distances in to the top gap of the shower track.
    This will make the top gap in the shower track, a small amount, wider and therefor make the bottom gap with the sliding hooks in narrower and stop these coming out..
View all instructions
