Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Events Hackerspaces Profiles Hackaday.com Tindie Marketplace Remoticon
Sign up Log in
Gravity Offload Sensing
Simulate moon level gravity to test a rover
Jordan RéjaudJordan Réjaud
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
69
0
1
1
Team (1)
  • Jordan RéjaudJordan Réjaud
Join this project's team
completed project
hardware
gravity offload moon rover cMU carnegie mellon
This project was created on 09/26/2015 and last updated 4 years ago.
Description
My team and I built a machine which simulates reduced moon-level gravity to test a moon rover.
We built a prototype sensing mechanism for this gravity simulator. The gravity offloading cord must always be on top of the object that you are simulating moon level gravity on in order to pull it up and "offload" a portion of the force of gravity acting upon the object. Thus, if the object moves, the cord must move at the same time.
Our sensing mechanism detects the angle offset of the object and sends commands to the tether cord motor controller to move it back on top of the object.
Details
Log In/Sign up to comment
Sign up with Github
OR
A simple test stand for a 1960`s motorcycle crankshaft.
Project Owner Contributor
Crankshaft Teststand
Heinz-Peter LiechteneckerHeinz-Peter Liechtenecker
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
High Power Experimental Rocket Platform
J. M. HopkinsJ. M. Hopkins
Animatronic replica of "Melvin" from Country Bear Jamboree
Melvin
A.M. SmithA.M. Smith
I am the co-founder of the Canadian startup Tyto Robotics Inc.
Co-founder of Tyto Robotics Inc.
Dominic RobillardDominic Robillard
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "Gravity Offload Sensing", please tell us the reason.
Send message
Remove Member
