close-circle
BlueSun ESP8266 WiFi 'o' Sonar
ESP8266 WiFi 360° Sonar sensor with graphic Web interface Gui
close
This project uses an ESP8266 series 12 WiFi module to create a true 360° sonar scanner mounted on a stepper motor. The output is displayed remotely as a HTLM5 Gui interface.
This project is part of my continuing exploration into low cost remote mapping of environments.
The design you see consists of a simple Stepper motor controlled directly by the ESP8266 WiFi module
, a Maxbotic Sonar transducer provides a 30cm - circa 6meter range.
The analogue output of the distance transducer is fed to the analogue input of the ESP8266.
The ESP8266 loggs a 360° scan and then outputs the data to a HTML5 web page.
The system allows for a very cost effective way for logging positional data remotely within a WiFi enable environment.
  • 1 × ESP8266 series 12 WiFi module
  • 1 × 28BYJ48 5V stepper motor with driver circuit Bog standard common stepper motor
  • 1 × MaxSonar - EZ0 (in my example) you could also use IR or sharp sensors
View project log
  • 1
    Step 1
    The sonar is mounted onto a 3D printed mount which in turn is mounted direct onto the stepper motor.
View all instructions
