Schematic
A project log for Nyan Board
A small ATtiny85 board playing the Nyan Cat tune.
dehipudeʃhipu 11/28/2016 at 10:439 Comments
I just realized that I never wrote about the schematic of the board. Sure, it's very simple, but for completeness' sake:
danjovic wrote 11/28/2016 at 12:05 point
I think the LEDs are inverted.
deʃhipu wrote 11/28/2016 at 12:14 point
Oops.
deʃhipu wrote 11/28/2016 at 12:16 point
Fixed, thanks!
K.C. Lee wrote 11/28/2016 at 11:50 point
The Amber LED could be in series for 5V I/O as they have forward voltage of 2.1-2.2V.
deʃhipu wrote 11/28/2016 at 12:02 point
I thought you always need a resistor on a LED, due to its non-linearity.
K.C. Lee wrote 11/28/2016 at 14:40 point
 You'll still need a series resistor to set the right current.  You could halve the amount of current consumption by having the LED wired in series instead of in parallel.
deʃhipu wrote 11/28/2016 at 15:00 point
Oh, I see. But I guess I can also achieve the same halving by using larger resistors.
K.C. Lee wrote 11/28/2016 at 15:08 point
No you are not as you are *always* using 2X the current because you are supplying 2 branches of LED instead of a single branch.
The power wasted in one of the series resistor *could* have powered the second LED.  You throw away about 2.8V in that resistor instead of 0.6V.
Ted Yapo wrote 11/28/2016 at 15:07 point
The upside to driving them in parallel is that it's more robust to Vf changes due to LED batch variation and ambient temperature.
In the series case, the total Vf is 2 x 2.2 = 4.4, leaving only 0.6 V to drop across the resistor.  So, you choose a 30-ohm resistor to allow 20 mA.  If you get a batch of LEDs with a low Vf, and/or the ambient temperature rises, the Vf might drop to 1.9 or less.  Now, you're driving 40 mA into the LEDs.
If you did them in parallel, you would choose (5-2.2)/.02 = 140 ohms.  If the Vf drops to 1.9 now, the LED is only getting 22 mA.
The downside is wasted power in the resistors in the parallel case.
