supply power
A project log for RGB 16 Segment LED
one does not simply order 50 ws2812b LEDs and has a 3D printer at home
davedarkodavedarko 10/01/2015 at 19:473 Comments
I wanted to power my arduino and the wsb2812bs from the same source when running, but didn't want to kill my usb port when programming, so I used some diodes from a rectifier.
davedarko wrote 11/04/2015 at 18:25 point
Looking at this makes me think I might have gotten away with one diode :D
deʃhipu wrote 10/01/2015 at 20:04 point
I think that Arduino has a mosfet in there that cuts off the USB power if you connect external power.
davedarko wrote 10/01/2015 at 20:11 point
I was worried that when I connect the VCCs that the current drawn by the ws2812bs would kill the usb connection. It's both 5V and I'm not using VIN.
