Better switch alignment using a 3D printed jig
A project log for Smaller Simone Giertz's Good Habit Tracker
A PCB with one column per month, each has approximately thirty switches in series and one LED at the end. 367 Switches. Pure Madness.
arduino-enigmaArduino Enigma 08/26/2018 at 17:490 Comments
@sdp8483 wrote in the comments to announce that he had created a 3D printed alignment jig in order to assemble his own Habit Tracker.
The design holds a column worth of switches and it both pushes the metal case down as well as ensure the separation between columns is fixed.
Here is a picture of his finished Habit Tracker. The switches do look indeed aligned.
The jig can be downloaded at Sam Perry's thingiverse page here:
https://www.thingiverse.com/thing:3018815
