PunchStation at la Saline Royale !
09/16/2016 at 11:42 • 0 commentsSome month ago i, and my hackerspace participated to an event/meet with some others hackerspaces/fablabs.
Reflect of water and light:
I took the PunchStation with me !La Saline Royale:
Video available here
received new magnets, everything is working fine
10/14/2015 at 14:25 • 0 commentsHello,
So i received new magnets (less strong) and with a hard disk magnet on the middle.Close view on the additional fan added:
Making 3mm washer for the fan:
And final test:
Mixing:
Moar !
Enjoy and drink responsibly !Here is a video... who seem blocked in some country due to music..
In case you can't view it, here is another link: http://www.dailymotion.com/video/x39mulo
First start and first fail
10/02/2015 at 10:07 • 0 commentsHello hackers,
So i started this project today and despite everything looking fine, my neodymium magnets are too strong for the motor !
I'm waiting to receive new batch of neodymium magnets from eBay !The goal is to put everything in a PSX, the motor and the rest must be relatively small.
For that i got a Coprel motor: AC 230V, 50Hz, 17W, 0,17 AmpFor my speed control i'm using a KBMC-23BV, 230 VAC, 50/60 Hz, 2.5 Amp
Main unit:
The motor is attached with 3 cable ties.
For the PSX i've used my dremel to remove a bit of plastic and did my CAD file with solidWorks to put the neodymium magnets, here are some pictures of the design:3D Printed:
But the plastic bend and magnets goes stuck on the motor due to the force.I plan to add a 40x40mm fan for cooling the motor and find new magnets and revise my CAD design to the according new magnets (or maybe using bakelite instead of plastic, i have no idea).
Power supply pinning of the PSX for future reference:
To be continued.
