Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Garter Gun
The best garter toss accessory ever! Shoot the garter with a pneumatic cannon.
John LeemanJohn Leeman
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 19
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
807
4
0
1
Team (1)
  • John LeemanJohn Leeman
Join this project's team
hardware
ongoing project
wedding pneumatic cannon
This project was created on 10/02/2015 and last updated 7 years ago.
Description
I wanted a unique way to toss the garter at our wedding. I thought about rubber band style guns, but didn't have the time to build one. A pneumatic cannon was a quick, simple, and fun solution! WARNING: This project has the potential to hurt you and others. Do not point the gun at anyone directly. Do not load heavy projectiles. Do not over pressurize the gun or it could fragment sending you and others to the hospital or graveyard. Use with brain engaged.
Components
  • 2 × 3/4" metal pipe nipple
  • 1 × 3/4" Air ball valve
  • 1 × 3' length of 1.5" PVC Pressure Rated
  • 1 × 3' length of 2" PVC Pressure Rated
  • 2 × 2" to 3/4" threaded PVC Bushing Pressure Rated
View all 19 components
Project Logs
Collapse
  • Wedding Success
    John Leeman • 12/01/2015 at 03:00 • 0 comments
    This garter gun was a hit! We had great fun with it at the wedding and even got some video from a drone (which was also our ring bearer) of the garter shot.
  • Test Fire
    John Leeman • 10/02/2015 at 17:43 • 0 comments
    Video of the garter gun test fire!
  • Build photos
    John Leeman • 10/02/2015 at 14:58 • 0 comments
    Here are some build photos to help everyone see how things come together. Use PVC glue, teflon tape, and be careful!
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
Alex Rich wrote 10/02/2015 at 17:52 • point
You may want to consider a sprinkler valve instead of a ball valve for quicker activation, once you're done shooting garters you can get maximum velocity with other projectiles that way.
John Leeman wrote 10/07/2015 at 20:59 • point
Yeah, I think that's the way to go. This was a last-minute design, but it ended up working great at the wedding. I hope to have the drone video of the shoot soon. Do you have a preferred supplier for the sprinkler valves online?
Alex Rich wrote 10/07/2015 at 21:06 • point
Yeah I believe we bought ours from this guy who pulled the crappy little solenoid valve that comes with it and swapped in a squeeze valve that opens much more quickly.  Of course you can do that yourself and it saves a few dollars, but we just paid for the value added service.  http://www.spudtech.com/store/index.php?main_page=product_info&products_id=13
John Leeman wrote 10/07/2015 at 22:11 • point
Thanks! I'll be ordering one probably! :)
3 methods for testing BJT
Project Owner Contributor
How to test transistors
Marius TaciucMarius Taciuc
This is a small scale - indoor aquaponics test project.
Automated Aquaponics Setup
Trent WainwrightTrent Wainwright
The 2015 Hackaday Prize
This project goal is to developp an autonomous way of filming RC plane during flight without the need of a 2nd person to do it.
Autonomous video recording
Walker EricWalker Eric
I wanted to go to Toshi station to pick up some power converters. My boss wanted me to build a moisture vaporator.
The Hackaday Prize Moisture Vaporator
BenchoffBenchoff
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "Garter Gun", please tell us the reason.
Send message
Remove Member
