Howdy, MSP430 ! All cool bro?
A project log for ArcReactorX
The more 'intuitive' arc reactor! Designed to get attention ;)
rohit-guptaRohit Gupta 04/12/2014 at 14:230 Comments
This is just to check if the microcontroller is happy in its place. No RESET line issues were detected. The power and programming interface worked fine.
You can see the programming wires in the picture below. It was programmed using the MSP430 launchpad.
I am using Energia inside which i run code which uses some of energia and some basic register level access at points where energia has not dug yet.
