Thermals
A project log for Cortex Guitar Board
Audio DSP board based on a Cortex-M4 microcontroller for experimenting with things like guitar effects and sound synthesis.
jonas-norlingJonas Norling 08/01/2016 at 06:570 Comments
I recently borrowed a thermal camera to figure out how hot the board gets, especially when powered from the higher end of the expected supply voltage range.
Heat camera image
This is an image of the board taken with a thermal imaging camera. The shot was taken after feeding the board with a 10V supply for an hour or so. The LDO—where the voltage is dropped to 3.3V—obviously shows up as hottest, peaking at about 74°C. Supply current is around 80 mA here, meaning that the LDO and the diode before it have to dump about half a Watt into the air and board.
The conclusion is that it's wise to feed the board with a lower voltage to keep losses down. No surprises there :-)
