From generic toner cartidge HP1102W printer, 346°F transfer temp - 10z copper , double sided - 1.6mm FR1 PCB.
JPEG Image - 1.38 MB - 02/29/2016 at 05:13
eye
Preview
download-circle
Download
Using a Krazy glue cap 'punch'
JPEG Image - 1.70 MB - 02/29/2016 at 05:13
eye
Preview
download-circle
Download
Used the Proxxon Press for this - 0.8mm bit.
JPEG Image - 940.44 kB - 02/29/2016 at 05:15
eye
Preview
download-circle
Download
Nice surface finish to grip toner.
JPEG Image - 1008.13 kB - 02/29/2016 at 05:14
eye
Preview
download-circle
Download
Isopropyl alcohol wipes (70 to 99%) with a good paper towel is fine.
JPEG Image - 1.06 MB - 02/29/2016 at 05:14
eye
Preview
download-circle
Download
Bobby pin used to 'punch' registration holes in toner transfer paper to align with the holes in the copper.
JPEG Image - 1.42 MB - 02/29/2016 at 05:13
eye
Preview
download-circle
Download
Bobby pins and painters tape
JPEG Image - 914.89 kB - 02/29/2016 at 05:13
eye
Preview
download-circle
Download
Bobby Pin registration into the drilled copper PCB registration holes and painters tape.
JPEG Image - 980.61 kB - 02/29/2016 at 05:13
eye
Preview
download-circle
Download
JPEG Image - 905.81 kB - 02/29/2016 at 05:13
eye
Preview
download-circle
Download
Final registration step.
JPEG Image - 835.74 kB - 02/29/2016 at 05:14
eye
Preview
download-circle
Download
8a-Toner-Transfer-laminator.mp4
Apache AL13P with my multi pass mod ( see other Hackaday project) running a double sided 'toner transfer' board in 1 pass.
MPEG-4 Video - 38.95 MB - 02/29/2016 at 05:40
download-circle
Download
8b-Toner on Copper.mp4
Finished the laminator toner transfer. took 2 -3 minutes with the single pass made up of micro passes as seen in the Toner transfer video.
MPEG-4 Video - 12.89 MB - 02/29/2016 at 05:22
download-circle
Download
Post transfer...look at the video (item 8)
eye
Preview
download-circle
Download
Layer 2 transferred along with layer 1
JPEG Image - 1.13 MB - 02/29/2016 at 05:14
eye
Preview
download-circle
Download
9c Foil-transfer.mp4
Doesn't have to be micro passes, 2 normal 'full speed' passes would do the job.
MPEG-4 Video - 36.65 MB - 02/29/2016 at 05:34
download-circle
Download
9d Remove-foil.mp4
Easy as that!
MPEG-4 Video - 30.75 MB - 02/29/2016 at 05:32
download-circle
Download
Note videos on foil transfer using the laminator and peeling it off.
JPEG Image - 1.89 MB - 02/29/2016 at 05:16
eye
Preview
download-circle
Download
JPEG Image - 1.82 MB - 02/29/2016 at 05:16
eye
Preview
download-circle
Download
Results after about 12 minutes in dilute nitric acid. Probably the 10th use of the acid mix. You can handle the board with your fingers for a minute or so....no risk, it is so harmless to skin. No staining, no burning etc.
JPEG Image - 948.00 kB - 02/29/2016 at 05:16
eye
Preview
download-circle
Download
JPEG Image - 977.76 kB - 02/29/2016 at 05:16
eye
Preview
download-circle
Download
VISE MOUNTED ON DRILL PRESS SLIDE BAR, SHOWING 6-32 SCREW ADJUSTMENT FOR LOCK DOWN.
JPEG Image - 2.22 MB - 02/27/2016 at 19:39
eye
Preview
download-circle
Download
BACK LIGHT SHINING THRU FR4, 1/16" PCB...THE ACTUAL VIEW IS MUCH CLEARER THAN THE PIC!
JPEG Image - 1.53 MB - 02/27/2016 at 19:39
eye
Preview
download-circle
Download
BOTTOM VIEW OF MINI VISE STABILIZER SCREW MOD. 6-32 X 1.5". IT LOCKS THE VISE ONTO THE DRILL PRESS SLIDE BAR FOR 3 DIMENSIONAL STABILITY.
JPEG Image - 1.81 MB - 02/27/2016 at 19:39
eye
Preview
download-circle
Download
