Double Sided using fresh HP toner @ 360F
A project log for PCB /SMT MAKER LAB @ Home
This project outlines how to do advanced PCB making at home with proper tooling. Tooling includes a laminator and hobby laser.
mosaicmercmosaicmerc 10/27/2017 at 03:100 Comments
Did a test with a bit more heat with a fresh OEM HP toner cart for the 1102W printer.
Very solid transfer and etch, no pin holing in the fills , did not use the extra foiling step. 5.5" x 3.25"PCB with SOIC part (28 pin) in centre and 0805 SMT parts.
Also on ALIEXPRESS search for M0.9*2.5 Copper Hollow Rivet , to make  handling vias simple.
