Displaying the time on 8x8 pixels.
Your project inspired me to make this.
https://hackaday.io/project/13431-iot-led-matrix-projector-clock
That is awesome! I like it :) I should try a projector build someday...
I made a similar version, based on Daniel's, that can switch among English, Spanish, Dutch, and French. http://pablo-sanchez.com/8x8-word-clock-with-rtc/
I can share the language layout if you are interested.
I built my own last year after I saw HaD post about it and decided to give SMD soldering a shot. My blog post about the process: http://www.andbosta.com/building-the-micro-word-clock/
Fine project. Would "skull" if a French version would be available on 8*8 dot. Super mega bonus for a bi-langual version (I know: this is a cruel challenge, almost unreachable)
Hi,
thanks for the comment! :-)
You are free to try your hands at the French version. So far, people have contributed Dutch, Hungarian and Spanish versions! (See GitHub)
I made one, but on a 14x9 matrix. It wasn't a watch, and I didn't have your space constraints. On the other hand, I didn't want to have the words cut.
I will try to make a 8x8 french one. It must be possible...
I'll keep you posted
Double-checked your design: you're missing gerber files.
Thanks! They've been added to GitHub! :-) Hope a .zip is fine
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
Cool project. Anything worth doing is worth miniaturizing.
Think you could add a battery and a few PCB-mounted wrist strap attachment points? This would make an awesome watch!
cpknight
saarbastler
ted
It is so great.
I *just* made a solar powered pocket word clock based on the PCB.
Together with a ME4056 lipo charger, coin cell, 30mA solar panel, 2 buttons (on/set) in a 51x35x15mm plastic case. Maybe I can send you pictures to publish here?
Thanks for sharing this!
