Hackaday.io Hackaday.io
Sign up Log in
Uranium Marble Ring Oscillator
danielDaniel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.3k views
4 comments
13 followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
1.3k
4
13
14
Team (1)
  • danielDaniel
Join this project's team
  • Youtube
  • Original design
hardware
completed project
uranium marble
This project was created on 10/06/2015 and last updated 10 years ago.
Description
Seven UV LEDs facing inwards on a circle around a uranium glass marble, wired as a ring oscillator to create a beautiful glowing/spinning effect. This is my take on the original design that has apparently been around since at least 2009 (at 26C3).
Details
Components
  • 1 × Uranium Marble
  • 7 × UV LEDs
  • 7 × 2N7000 transistor Discrete Semiconductors / Diode-Transistor Modules
  • 7 × 300 Ω resistor
  • 7 × 33 kΩ resistor
View all 7 components
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
lantramnamcodon wrote 05/08/2017 at 15:59 • point
have you tried to make laser with uranium glass?However that could have made you cancer.
Rjpope42 wrote 02/15/2016 at 16:02 • point
Thanks for the reply, I got some 385 and some 400nm from digikey, the 400nm were cheaper and work better
Rjpope42 wrote 02/07/2016 at 05:32 • point
Very nice!
What wavelength LEDs did you use?
Daniel wrote 02/15/2016 at 11:06 • point
Sorry, a friend had those LEDs just lying around so I don't have any info on that. You can clearly see them emitting visible light... if that helps. Not sure if the marble reacts to one specific wavelength..
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Uranium Marble Ring Oscillator", please tell us the reason.
Send message
Remove Member
