I learned about a new FOSS project a few weeks ago: apio. It's stated mission is:
Experimental open source micro-ecosystem for open FPGAs. Based on platformio. Apio is a multiplatform toolbox, with static pre-built packages, project configuration tools and easy commands to verify, synthesize, simulate and upload your verilog designs.
That sounded pretty good to me. It was easy to install on my RPi3:
pip install apioThat just installs the apio "shell". In order to get all the synthesis, simulation, and board tools, I used the command:
apio install --all
That automatically downloads and installs some system utilities, the Icestorm FPGA toolchain, the iverilog simulator, and some design examples for several types of iCE40 FPGA boards. Once that was completed, I could check to see what boards were supported:
pi@raspberrypi:~ $ apio boards --list
Supported boards:
Board FPGA Type Size Pack
icoboard iCE40-HX8K-CT256 hx 8k ct256
icezum iCE40-HX1K-TQ144 hx 1k tq144
icestick iCE40-HX1K-TQ144 hx 1k tq144
go-board iCE40-HX1K-VQ100 hx 1k vq100
iCE40-HX8K iCE40-HX8K-CT256 hx 8k ct256
Use `apio init --board <boardname>` for creating a new apio proyect for that board
What!?!? No CAT Board in the list!?! I needed to fix that situation. I poked around in the apio Python code and found a likely file at apio/resources/boards.json. Inside that file, I pretty much copied the existing entry for the icoboard with a few modifications: "Cat-board": {
"fpga": "iCE40-HX8K-CT256",
"prog": "litterbox",
"check": {
"arch": "linux_armv7l"
The only thing I changed (besides the board identifier) was the "prog" entry to list the litterbox utility that uploads bitstreams from the RPi3 to the FPGA on the CAT Board.I also had to modify the following section of the SConstruct file in the same directory:
# -- Upload the bitstream into FPGA
upload_cmd = ''
if PROG == 'ftdi':
upload_cmd = 'iceprog{0} -d i:0x0403:0x6010:{1} $SOURCE'.format(
EXT, DEVICE)
elif PROG == 'gpio':
# Icoboard + RPI2: sram
upload_cmd = 'export WIRINGPI_GPIOMEM=1; icoprog -p < $SOURCE'
elif PROG == 'litterbox':
# Cat Board + RPI2,3
upload_cmd = 'sudo litterbox -c $SOURCE'This just adds the command for uploading a bitstream using the litterbox utility.
Finally, after a little more poking around, I found the apio/managers/scons.py file and added the following code to its upload function:
# -- Litterbox
elif programmer == 'litterbox':
# Device argument is ignored
if device and device != -1:
click.secho(
'Info: ignore device argument {0}'.format(device),
fg='yellow')
# Check architecture
arch = self.resources.boards[board]['check']['arch']
current_arch = util.get_systype()
if arch != current_arch:
# Incorrect architecture
click.secho(
'Error: incorrect architecture: RPI2 or RPI3 required',
fg='red')
return 1This does a sanity check to make sure the upload process for the CAT Board is occurring on an RPi2 or RPi3.
Now when I regenerate the board list, I can see the CAT Board:
Supported boards:
Cat-board iCE40-HX8K-CT256 hx 8k ct256
Use `apio init --board <boardname>` for creating a new apio proyect for that boardOnce my modifications were complete, I went into the directory for the LED blinker and used the following command to indicate that this design was intended for the CAT Board:
apio init --board Cat-board
This creates an apio.ini file with a single line of text indicating the board type:
{"board": "Cat-board"}From there, it's an easy step to compile the design and upload it to the CAT-board:
apio uploadIf the bitstream in the directory is missing or out of date, apio will rebuild the design using the Icestorm tools. Then it uploads the bitstream to the CAT Board using the litterbox utility. After that, the LED starts blinking. Success!
The apio tool makes it really easy to install and apply the iCE40 FPGA tools. Also, the authors have added my modifications so apio now supports the CAT Board right out of the box.
Dave Vandenbout
