3D Print Files.zipAn upload of the 3D print STL file for the first waterfall diagram generated that had interesting results. This also contains an excel file with the raw data.x-zip-compressed - 40.63 MB - 01/30/2019 at 10:31 |
Final Post Selection for Upload.zipThis contains a 3 minute RAW .WAV audio recording along with the "interesting" high-pass filtered "sound" of the grid that is featured up the top in the youtube video. Also included are the results (jpg) from the matlab run. Basically, this is the last set of results obtained before I finished this project. I'd just upload everything, but there is a 50MB limit per file upload...x-zip-compressed - 29.89 MB - 01/12/2019 at 09:23 |
Hottest Day on Record.zipThis contains the images from my project log on the hottest day ever in Adelaide. Unfortunately, it's only the images as the data is way beyond the 50MB size limit. Still, it's always nice to have them collected here and not lost in the endless log list.x-zip-compressed - 2.95 MB - 01/28/2019 at 01:50 |
WaterFall Era Pics Selection.zipSelection of some JPGs of MATLAB plots, along with two actual plots in the MATLAB figure format. I'd like to just upload everything, but the waterfall plots are making these figures huge and that's just not possible any more. From now on it'll just by JPGs.x-zip-compressed - 38.32 MB - 01/10/2019 at 11:03 |
MATLAB Scripts.zipThe MATLAB code used to acquire data. Configuration is made in "main" and "sample grabber". Realistically, don't expect it to work with different sample rates, etc. without modification. Or just don't expect it to work at all. Run everything from "main". Written in MATLAB R2017a.x-zip-compressed - 36.82 kB - 01/10/2019 at 10:46 |
Results Images.zipThis is a collection of PNGs/JPGs of results and some other things - Check these out before the other results if you just want a feel for things.x-zip-compressed - 1.60 MB - 01/01/2019 at 07:06 |
Good Result.zipPart 3/3: This is a "good" 16 hour results grab (no weird transients). This contains both a MATLAB figure (MATLAB 2017a) and a JPG image.x-zip-compressed - 18.07 MB - 01/01/2019 at 06:13 |
Results Set 1.zipPart 2/3: More MATLAB figures of results (MATLAB 2017a). This is more of a results dump than anything cohesive.x-zip-compressed - 45.76 MB - 01/01/2019 at 05:14 |
Results Set 2.zipPart 1/3: Some MATLAB figures of results (MATLAB 2017a). This is more of a results dump than anything cohesive.x-zip-compressed - 34.39 MB - 01/01/2019 at 05:05 |
Grid-2-Audio.pdfA 3D PDF of the Grid-2-Audio PCB. Start here if you want a good look at the 3D model/layout. You'll need to download this and open it with Adobe outside of your web browser (probably). - This is the only 3D model uploaded that contains the additional "CF" capacitor across the final op-amp's feedback path.Adobe Portable Document Format - 599.66 kB - 10/06/2018 at 12:07 |
Render Collection Upload.rarA collection of my best renders from Fusion 360, along with the Fusion 360 file itself should anyone else care to indulge. The selection is somewhat limited due to the 50MB file limit.RAR Archive - 48.96 MB - 09/27/2018 at 11:55 |
Enclosure.rar3D models of the parts of the device enclosure (Autodesk/STEP/STL). This now includes the revised main enclosure extrusion with additional ventilation and the fan cooling add-on.RAR Archive - 4.36 MB - 11/03/2018 at 07:28 |
PCB 3D Models.rar3D models of the PCB design (Step, STL & PDF).RAR Archive - 1.46 MB - 09/08/2018 at 03:57 |
GerbersV3.rarGerber files for the design. Note that this rar can be directly uploaded to gerber viewers and previewed/manufactured. The top/bottom paste layers are not included (can be generated from the Altium files though). - Contains "CF" op-amp filter (i.e. latest).RAR Archive - 40.34 kB - 10/06/2018 at 12:11 |
BOM Grid-2-Audio.xlsxA bill-of-materials list for the components to be loaded onto the PCB. "CF" is reflected here.sheet - 11.81 kB - 10/06/2018 at 12:14 |
Altium.rarDesign files for the entire schematic/layout. This is the latest version as it includes the "CF" capacitor to stop the opamp oscillating.RAR Archive - 1.14 MB - 10/06/2018 at 12:25 |
