Heat Problem is Under Control
A project log for Grid-2-Audio
A convenient adapter to view the electrical grid waveform through your PC's sound card.
david-scholtenDavid Scholten 11/03/2018 at 07:040 Comments
Okay, so after developing another version of the cooling add-on (that's far more mechanically robust and requires no printing supports), I have finally managed to keep the thing cool.
And by cool I mean stupidly cool - We're talking only a 5-10 degrees Celsius rise above the ambient.
It turns out it needed minimal air flow (of any amount) to move the little amount of heat it's producing.
Here we go:
It's not the prettiest looking case accessory, but it certainly gets the job done via the 1W/5V USB fan. Now instead of going from 23C to 75C in 2 hours it goes from 23C to 30C in 20 minutes.
I also had a look at the waveform directly to see if the fan attachment was coupling any EMI to the measurement circuit. Turns out it isn't! I also tuned the output filtering pF capacitor a little to ensure that the RF/op-amp oscillation fluff was minimised.
Next step is the MATLAB stuff!
